Salta al contenuto principale
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
Cosa ti serve
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: passo 1, immagine 1 di 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: passo 1, immagine 2 di 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 2, immagine 1 di 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 2, immagine 2 di 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 3, immagine 1 di 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: passo 4, immagine 1 di 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: passo 4, immagine 2 di 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 5, immagine 1 di 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 6, immagine 1 di 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: passo 7, immagine 1 di 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: passo 7, immagine 2 di 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 8, immagine 1 di 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: passo 9, immagine 1 di 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Conclusione
Jacob
Membro da: 03/11/15
757 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 206
