Cambiamenti ad iMac Intel 21.5" Retina 4K Display (2017) RAM and SATA Hard Drive Upgrade Introduzione
Modifica in base a Sam Goldheart-
Modifica approvata da Sam Goldheart
- Prima di
- Dopo il
- Invariato
Dispositivo |
Type |
Thing |
Title |
Introduction |
This guide details removing the logic board in a 2017 iMac 4K in order to remove or replace the RAM and the hard drive. Some images in this guide were taken from the 2015 model, which has some small visual differences.
Opening this device requires cutting through adhesive that will need to be [https://www.ifixit.com/Guide/iMac+Intel+21.5-Inch+Retina+4K+Display+Adhesive+Strips+Replacement/64210|new_window=true|reapplied] after you finish the repair. Be sure to test your new RAM before sealing the iMac with the adhesive strips.
This guide is marked "potentially dangerous" because it requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the board by the edges and do not touch surface components.
Time Required Min |
Nessuna stima
Time Required Max |
Nessuna stima
Imageid |
Prima di
![]() ![]() Dopo il
Difficulty |
Moderate
Conclusion |
Author | |
Public |
No
Summary |
Prerequisiti Guida
- #1 era empty ma ora è iMac Intel 21.5" EMC 2805 Display Assembly Replacement.
- #2 era empty ma ora è iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement.
- #3 era empty ma ora è iMac Intel 21.5" Retina 4K Display Assembly Replacement.
- #4 era empty ma ora è iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement.
- #5 era empty ma ora è iMac Intel 21.5" Retina 4K Display Hard Drive Brackets Replacement.
- #6 era empty ma ora è iMac Intel 21.5" EMC 2805 Power Supply Replacement.
- #7 era empty ma ora è iMac Intel 21.5" Retina 4K Display Power Supply Replacement.
- #8 era empty ma ora è iMac Intel 21.5" Retina 4K Display Fan Replacement.
- #9 era empty ma ora è iMac Intel 21.5" Retina 4K Display Hard Drive Assembly Replacement.
- #10 era empty ma ora è iMac Intel 21.5" Retina 4K Display Hard Drive Replacement.
- #11 era empty ma ora è iMac Intel 21.5" Retina 4K Display Hard Drive Tray Replacement.
- #12 era empty ma ora è iMac Intel 21.5" Retina 4K Display (2017) RAM Replacement.
Strumenti
- Plastic Cards x1 added.
- iMac Opening Tool x1 added.
- Tweezers x1 added.
- Spudger x1 added.
- iMac Service Wedge x1 added.
- Phillips #00 Screwdriver x1 added.
- T10 Torx Screwdriver x1 added.
- T8 Torx Screwdriver x1 added.
- T5 Torx Screwdriver x1 added.
Contrassegni
- Potentially Dangerous added.
- In Progress added.
