Cambiamenti ad MacBook Pro 15" Unibody Mid 2010 Matte Finish LCD Replacement Introduzione
Modifica in base a Mike K-
- Prima di
- Dopo il
- Invariato
Dispositivo |
Type |
Thing |
Title |
Introduction |
This guide covers removal and replacement of the Matte Finish LCD. Aside from your screen not being glossy or glared, you know you have a Matte Finish LCD if you have an approx. 14mm brushed aluminum bezel around your screen.
Most people DON'T have this bezel, and so should use the existing Glossy LCD replacement guild instead: [guide|3581] .
The only difference between the Matte Finish LCD and Glossy LCD version of the MacBook Pro is the display assembly. The Matte Finish LCD differs from the Glossy LCD in two ways:
# The aluminum bezel.
# The exterior glass of the matte display is optically bonded to the LCD, so you cannot remove the glass with suction cups. (On the bright side, any new matte LCD you purchase comes with the cover glass already bonded!)
Time Required Min |
Nessuna stima
Time Required Max |
Nessuna stima
Difficulty |
Moderate
Conclusion |
Author | |
Public |
No
Summary |
Prerequisiti Guida
- #1 era empty ma ora è MacBook Pro 15" Unibody Mid 2010 Display Replacement.
Strumenti
- Binder Clip 1.25" Binder Clips x7 added.
- Precision Utility Knife x1 added.
- Heat Gun x1 added.
- Phillips #00 Screwdriver x1 added.
- Small Roller Pin About 1" Diameter x1 To roll over VHB tape. I used a 30mm socket. added.
- Spudger x1 added.
- Straight Edge x1 added.
- T6 Torx Screwdriver x1 added.
- Tri-point Y0 Screwdriver x1 added.
Parti
- Isopropyl Alchool x1 added.
- 3M 4905 VHB Tape x1 added.
Contrassegni
- In Progress added.
- Member-Contributed Guide added.
