Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad How to Safely Raise a Vehicle Using Ramps Introduzione
Modifica in base a Jeff Suovanen-
Modifica approvata da Jeff Suovanen
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]Car and Truck
Type
[ ]technique
Title
[ ]How To Safely Raise A Vehicle Using Ramps
Introduction
Used properly, ramps can be a safer alternative to raising your vehicle with a jack and jack stands. Ramps can also be easier and faster, especially if your car sits low to the ground where it's difficult to see the jack points. [ … ] Keep in mind that your vehicle won't be level when using ramps, since you can only use ramps at one axle. Therefore, ramps aren't advised for changing fluids (such as motor oil) because having the vehicle tipped up at an angle can prevent fluids from draining fully. [ … ] If you'd rather raise your car or truck using a jack and jack stands, follow this guide instead.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
[ ]Raise a car or truck without the need for jacks or jack stands by using automotive ramps.
Contrassegni
  • In Progress added.
Passi
Step #: 1
Prima di
Dopo il
