Salta al contenuto principale
Cambiamenti ad BCG800XL Grinder Jamming due to Worn Impeller Introduzione
Modifica in base a Ben Gottemoller-
Modifica approvata da Ben Gottemoller
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]BCG800XL
Type
[ ]replacement
Thing
[ ]Coffee grounds impeller
Title
[ ]BCG800XL grinder jamming due to worn Impeller
Introduction
[ ]This guide will walk through impeller replacement to fix the most common cause of jamming with the BCG800XL Smart Grinder from Breville.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
[ ]The BCG800XL grinder from Breville jams and makes a "gears stripping" sound. This can be a stripped drive gear, but is more commonly a worn out coffee-grounds impeller (Visible beneath burrs). The impeller is needed to push the grounds out of the chute.
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
