Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad Canon PowerShot SX200 IS Lens Disassembly Introduzione
Modifica in base a Philip Le Riche-
Modifica approvata da Philip Le Riche
Prima di
Dopo il
Invariato
Dispositivo
[ ]Canon PowerShot SX200 IS Lens Disassembly
Type
[ ]replacement
Thing
[ ]Zoom lens assembly
Title
[ ]Canon PowerShot SX200 IS Lens Disassembly Zoom lens assembly Replacement
Introduction
This guide is directly applicable only to this one specific model, nevertheless, other Canon compact camera lenses are likely to follow similar principles of operation and methods of construction. [ … ] You will require a fair amount of patience as reassembly is a little tricky. Note that it is very easy to get fingermarks or dust on the optical components but much harder to completely remove them. Particularly on the focussing lens and the image sensor, any contamination will have a significant or major effect on image quality. [ … ] You will need small cross-head and flat screwdrivers and a small craft knife. Additionally, a pair of fine tweezers will be helpful, and cocktail sticks are useful for releasing ribbon cables from their sockets. If you need to clean the optical components you will need some isopropyl alcohol and non-linting cotton swabs or lint-free cloths. Unless your eyes can focus at distances less than 10cm a magnifying glass or jeweller's eye loupe will be helpful.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
[ ]A previous guide showed the disassembly of the Canon PowerShot SX200 IS but stopped short of disassembling the lens. The present guide should allow a stuck lens or Lens Error to be diagnosed and hopefully fixed.
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
Step #: 4
Prima di
Dopo il
Step #: 5
Prima di
Dopo il
Step #: 6
Prima di
Dopo il
