Salta al contenuto principale
Cambiamenti ad How to check Mercedes W123 Fuses Introduzione
Modifica in base a Nicolas Siemsen-
Modifica approvata da Nicolas Siemsen
Prima di
Dopo il
Invariato
Dispositivo
Mercedes W123
Type
maintenance
Title
Mercedes W123 Fuse Maintenance
Introduction
It's important to check the fuses on your W123 car, especially if you haven't in a long time or if the car is new to you.
A blown fuse can often be the culprit for what seems to be larger electrical problems.
Additionally, there are certain kinds of fuses that do not work well in the W123 fuse box and these can lead to problems later on if not replaced now.
Learn to check your fuses and replace any that need it.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Very easy
When done, test the devices that are attached to the fuses you replaced to see if they work as they should.
Author
Public
No
Summary
The electrical system in the W123 cars is simple, and generally reliable. One of the weak points would definitely be the old fuses in the fuse box. Check yours, and consider replacing any bad ones now.
Contrassegni
  • In Progress added.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
Step #: 4
Prima di
Dopo il
Step #: 5
Prima di
Dopo il
Step #: 6
Prima di
Dopo il
Step #: 7
Prima di
Dopo il
