Salta al contenuto principale
Cambiamenti ad Mercedes W123 Brake Line, Front Driver's Side Replacement Introduzione
Modifica in base a Nicolas Siemsen-
Modifica approvata da Nicolas Siemsen
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]Mercedes W123
Type
[ ]replacement
Thing
[ ]Front Driver's Side Hard Brake Line
Title
[ ]Mercedes W123 Front Driver's Side Hard Brake Line Replacement
Introduction
The majority of your brake system is composed of hard metal lines that, just before reaching the calipers, connect with soft rubber hoses. Normally the hoses are what wear out and need to be replaced, but sometimes you'll have a need to replace the hard lines. They can rust out inside if brake fluid is not changed often enough, they can seize to the rubber hoses and the nuts can round off on the end, etc. [ … ] Please note that when working with brake fluid that it is extremely corrosive to paint. If it gets any painted part on your vehicle be sure to rinse it thoroughly. [ … ] As you proceed through this guide be sure to collect any fluids in a suitable drip pan and also to dispose of old fluids properly.
Time Required Min
15 minuti
Time Required Max
15 minuti
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
While they don't wear out, they can sometimes crack, or it's possible that the 11mm nut on the end of the line gets rounded off while replacing the soft rubber hoses. [ … ] Learn to replace your front driver's side hard line with this guide.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
Step #: 4
Prima di
Dopo il
Step #: 5
Prima di
Dopo il
