Salta al contenuto principale
Cambiamenti ad Ukujamisela Ipompo Yehlathi Yesikhuphukeli Sephayiphu Edlulisa Amanzi (Usebenzisa Ipoto Yennyawo Ezintathu) Introduzione
Modifica in base a iRobot-
Modifica approvata da iRobot
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]Bush Pump
Type
[ ]replacement
Thing
[ ]Riser Main
Title
[ ]Replacing Bush Pump Riser Main (Using a Tripod)
Introduction
[ ]Follow this guide to remove the sections of riser main from a Bush pump. You can either remove the entire riser main for replacement, or just remove and replace or repair a broken section.This guide uses the help of a tripod to lift the riser main. It can, alternatively, be lifted using lifting spanners, but a tripod allows the process to be done by two people. Still use caution when using a tripod.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
Summary
[ ]Remove and replace the riser main.
Contrassegni
  • In Progress added.
