Salta al contenuto principale
Cambiamenti ad Removing a Solid-State Drive (SSD) From a PC Introduzione
Modifica in base a Nguyen Nguyen-
Modifica approvata da Nguyen Nguyen
Prima di
Dopo il
Invariato
Dispositivo
PC Desktop
Type
replacement
Thing
SSD (Solid-State Drive)
Title
Introduction
A solid-state drive may need to be removed from a PC when it is broken, being replaced, or simply no longer needed. Removing a solid-state drive from a PC is a straightforward job that will only require a Phillips-head screwdriver. Depending on the case the PC is housed in, multiple sizes of screws may be necessary to remove, in which case screwdrivers of a different size may be needed. The two most important things to remember are to keep track of the screws as you remove them to reinstallation go smoothly, and to avoid damaging the PC with static electricity by wearing an anti-shock wristband.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
Author
Public
No
Summary
This guide will provide instructions on how to safely remove and replace the SSD, or solid-state drive, in your desktop computer.
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
