Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad Microsoft Surface Pro 3 Kickstand Replacement Introduzione
Modifica in base a Sarah Westberg-
Modifica approvata da Sarah Westberg
Prima di
Dopo il
Invariato
Dispositivo
[ ]Microsoft Surface Pro 3
Type
[ ]replacement
Thing
[ ]Kickstand
Title
[ ]Microsoft Surface Pro 3 Kickstand Replacement
Introduction
[ ]The kickstand on your Microsoft Surface Pro 3 is such a convenient feature. When you want to prop it up you can do it—but not just in one position, in this version you can tilt it at three angles! If your kickstand has worn out or broken and is no longer holding up your device, use this guide to replace it. The process is very simple and doesn’t require taking the Surface Pro 3 apart, you’re just removing the kickstand itself.
Time Required Min
10 minuti
Time Required Max
10 minuti
Imageid
Prima di
Dopo il
Difficulty
Easy
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
[ ]If your Microsoft Surface Pro 3 kickstand has broken off or is no longer holding the device up as it should, use this guide to replace it.
Strumenti
  • T4 Torx Screwdriver x1 added.
Parti
  • Surface Pro 3 Kickstand x1 added.
Contrassegni
  • In Progress added.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
