Salta al contenuto principale
Cambiamenti ad How to fix iPhone 6S/6S+ home button, when home button click does not work. Introduzione
Modifica in base a Jon-
Modifica approvata da Jon
Prima di
Dopo il
Invariato
Dispositivo
iPhone 6S and 6S Plus Home Button
Type
technique
Title
Introduction
There is yet another issue that is starting to be more common among the iPhone 6 and 6S variety phones. The home button no longer registers a click, but the touch ID still works.
Symptoms may include:
* Only registers click occasionally.
* Only works when the home button bracket is not attached to the LCD.
* Only works if the button is held or twisted a certain way.
* Will not register click at all.
3U tools should still be able to recognize the home button, and Touch ID should still work. If they do not, this guide will not fix those problems.
Time Required Min
20 minuti
Time Required Max
20 minuti
Imageid
Prima di
Dopo il
Difficulty
Difficult
After testing the home button and confirming that the repair worked, you can re-assemble your device.
Author
Jon
Public
No
Summary
A walk through for how to fix a specific issue starting to show up with iPhone 6S and 6S+ home buttons.
Issue: touch ID works, but the button won't click.
Prerequisiti Guida
Strumenti
  • P2 Pentalobe Screwdriver iPhone x1 added.
  • Suction Handle x1 added.
  • Spudger x1 added.
  • Tweezers x1 added.
  • Phillips #000 Screwdriver x1 added.
  • iFixit Opening Tool x1 added.
  • iOpener x1 Recommended, not required added.
  • STEREO MICROSCOPE (Optional) x1 added.
  • Soldering Workstation x1 added.
Ricambi
  • iPhone 6s Plus Home Button Assembly x1 added.
  • iPhone 6s and 6s Plus Home Button Gasket x1 added.
  • iPhone 6s Plus Home Button Bracket x1 added.
  • iPhone 6s Plus Display Assembly Adhesive x1 added.
  • iPhone 6s Home Button Assembly x1 added.
  • iPhone 6s Home Button Bracket x1 added.
  • iPhone 6s Display Assembly Adhesive x1 added.
  • Silicone Modified Conformal Coating x1 added.
  • Microsoldering Jump Wire (Insulated) x1 added.
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
