Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad Acer Aspire 5742 Screen Assembly Replacement Introduzione
Modifica in base a Philip Le Riche-
Modifica approvata da Philip Le Riche
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]Acer Aspire 5742
Type
[ ]replacement
Thing
[ ]Screen complete
Title
[ ]Acer Aspire 5742 Screen Replacement
Introduction
If your screen is cracked or non-functional you have two options: * You can replace the entire laptop lid assembly including the LCD panel, web cam, microphone, WiFi aerials, case and hinges. You may wish to do this if the plastic case is damaged. * If only the LCD panel needs replacing then there is much less preliminary disassembly to do, but bear in mind that the LCD is delicate and you need to take care not to crack your new one. [ … ] If the problem is simply that the screen is blank though undamaged as far as you can see, there is a small chance that he video cable needs reseating either at the motherboard or at its connection behind the LCD panel.
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Prerequisiti Guida
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
