Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad How to Enable the Charging Chime on a Mac Laptop with a MagSafe Charger Introduzione
Modifica in base a Aaron Cooke-
Modifica approvata da Aaron Cooke
Eliminato
Aggiunto
Invariato
Dispositivo
[ ]Mac Laptop
Type
[ ]technique
Title
[ ]How to Enable the Charging Chime on a Mac Laptop with a MagSafe Charger
Introduction
Newer Mac Laptops have USB-C instead of MagSafe or MagSafe 2 for charging. When you insert your USB-C power adapter into your Mac Laptop with a USB-C port you will hear a charging chime that verifies your Mac Laptop is charging. Older Mac Laptops without USB-C do not have this function. You can enable this charging chime with this simple terminal command. [ … ] PS: The charging chime on the newer Mac Laptops is the exact same chime used on iPhones and iPads to verify charging on those devices too.
Time Required Min
1 minuto
Time Required Max
2 minuti
Imageid
Prima di
Dopo il
Difficulty
Very easy
[ ]To disable the charging chime, simply change -bool true; in the command above to -bool false;
Author
Public
No
Summary
[ ]Enable the charging chime on older Mac Laptops without USB-C.
Contrassegni
  • In Progress added.
  • Member-Contributed Guide added.
Passi
Step #: 1
Prima di
Dopo il
