Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Cambiamenti ad Battery Adhesive Strips Replacement for iPhone 8, 8 Plus, XR, SE 2020 Introduzione
Modifica in base a Jeff Suovanen-
Modifica approvata da Jeff Suovanen
Prima di
Dopo il
Invariato
Dispositivo
[ ]iPhone
Type
[ ]replacement
Thing
[ ]iPhone Battery Adhesive Strips
Title
[ ]iPhone 8 and 8 Plus Battery Adhesive Strips Replacement
Introduction
Use this guide to correctly apply replacement battery adhesive strips in your iPhone 8 or 8 Plus. Any time you remove the battery, these strips must be replaced. The strips are easily damaged if not applied correctly, so you may want to have a spare set of strips on hand if following this guide for the first time. [ … ] These adhesives trips are shaped differently from prior-generation iPhones due to the presence of the wireless charging coil in the iPhone 8 and 8 Plus. The coil lies directly underneath the battery, which is secured with four adhesive strips that are contoured around the coil to avoid damaging it. [ … ] Before you begin, you should have removed the battery by following one of the guides below. [ … ] * [https://www.ifixit.com/Guide/iPhone+8+Battery+Replacement/101279|iPhone 8 Battery Replacement] * [https://www.ifixit.com/Guide/iPhone+8+Plus+Battery+Replacement/98260|iPhone 8 Plus Battery Replacement]
Time Required Min
Nessuna stima
Time Required Max
Nessuna stima
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your device, follow these instructions in reverse order.
Author
Public
No
Summary
[ ]Replace the adhesive strips that secure the battery in the iPhone 8 and 8 Plus.
Contrassegni
  • In Progress added.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
Step #: 4
Prima di
Dopo il
