Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Cambiamenti ad iMac Intel 21.5" EMC 3068 RAM Replacement Introduzione
Modifica in base a Adam O'Camb-
Modifica approvata da Adam O'Camb
Prima di
Dopo il
Invariato
Dispositivo
[ ]iMac Intel 21.5" EMC 3068
Type
[ ]replacement
Thing
[ ]RAM
Title
[ ]iMac Intel 21.5" Retina 4K Display (2017) RAM Replacement
Introduction
This guide details removing the logic board in a 2017 iMac 4K in order to remove or replace the RAM. [ … ] Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure. [ … ] This guide is marked "potentially dangerous" because it requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the board by the edges and do not touch surface components.
Time Required Min
1 ora
Time Required Max
3 ore
Imageid
Prima di
Dopo il
Difficulty
Moderate
[ ]To reassemble your iMac, follow these instructions in reverse order.
Author
Public
Summary
[ ]Learn how to replace or upgrade the RAM in your 2017 Retina 4K iMac.
Strumenti
  • iMac Service Wedge x1 added.
  • iMac Opening Tool x1 added.
  • Plastic Cards x1 added.
  • Tweezers x1 added.
  • Spudger x1 added.
  • Phillips #00 Screwdriver x1 added.
  • T8 Torx Screwdriver x1 added.
  • T10 Torx Screwdriver x1 added.
  • T5 Torx Screwdriver x1 added.
Parti
  • iMac Intel 21.5" Mid 2017 RAM Upgrade Kit x1 (featured) added.
  • iMac Intel 21.5" (2012-2017) Adhesive Strips x1 added.
  • 16 GB DDR4 PC4-19200 2400Mhz RAM x1 added.
Contrassegni
  • Featured Guide added.
Passi
Step #: 1
Prima di
Dopo il
Step #: 2
Prima di
Dopo il
Step #: 3
Prima di
Dopo il
Step #: 4
Prima di
Dopo il
Step #: 5
Prima di
Dopo il
Step #: 6
Prima di
Dopo il
Step #: 7
Prima di
Dopo il
Step #: 8
Prima di
Dopo il
Step #: 9
Prima di
Dopo il
Step #: 10
Prima di
Dopo il
Step #: 11
Prima di
Dopo il
Step #: 12
Prima di
Dopo il
Step #: 13
Prima di
Dopo il
Step #: 14
Prima di
Dopo il
Step #: 15
Prima di
Dopo il
Step #: 16
Prima di
Dopo il
Step #: 17
Prima di
Dopo il
Step #: 18
Prima di
Dopo il
Step #: 19
Prima di
Dopo il
