Salta al contenuto principale
d.light Solar Lantern S2 Battery Replacement
Cosa ti serve
  1. d.light Solar Lantern S2 Battery Replacement, Battery: passo 1, immagine 1 di 2 d.light Solar Lantern S2 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: passo 2, immagine 1 di 3 d.light Solar Lantern S2 Battery Replacement: passo 2, immagine 2 di 3 d.light Solar Lantern S2 Battery Replacement: passo 2, immagine 3 di 3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: passo 3, immagine 1 di 3 d.light Solar Lantern S2 Battery Replacement: passo 3, immagine 2 di 3 d.light Solar Lantern S2 Battery Replacement: passo 3, immagine 3 di 3
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team S2-G3, Harley Fall 2017 Membro di IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Membri
3 Guide realizzate
Un commento
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 50
Tutti i Tempi: 2,060
