Salta al contenuto principale
bObi Robotic Vacuum Screen Replacement
Cosa ti serve
  1. bObi Robotic Vacuum Screen Replacement, Top Cover: passo 1, immagine 1 di 2 bObi Robotic Vacuum Screen Replacement, Top Cover: passo 1, immagine 2 di 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Screen Replacement: passo 2, immagine 1 di 3 bObi Robotic Vacuum Screen Replacement: passo 2, immagine 2 di 3 bObi Robotic Vacuum Screen Replacement: passo 2, immagine 3 di 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Screen Replacement: passo 3, immagine 1 di 3 bObi Robotic Vacuum Screen Replacement: passo 3, immagine 2 di 3 bObi Robotic Vacuum Screen Replacement: passo 3, immagine 3 di 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Screen Replacement: passo 4, immagine 1 di 3 bObi Robotic Vacuum Screen Replacement: passo 4, immagine 2 di 3 bObi Robotic Vacuum Screen Replacement: passo 4, immagine 3 di 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Screen Replacement, Screen: passo 5, immagine 1 di 2 bObi Robotic Vacuum Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Remove the four screws that secure bObi's screen and lift the whole piece out.
    • Put the replacement screen in the open space.
  6. bObi Robotic Vacuum Screen Replacement: passo 6, immagine 1 di 2 bObi Robotic Vacuum Screen Replacement: passo 6, immagine 2 di 2
Conclusione
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
Chelsea
Membro da: 09/24/14
2.278 Reputazione
31 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 160
