Introduzione
For assistance putting bObi back together, follow the guide on closing bObi: Closing bObi's Cover Post-Repair
Strumenti
Parti
Nessuna parte specificata.
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
All of bObi’s wall detection sensors are plugged in to a small circuit board on the underside of the cover.
Refer to bObi’s check up test in order to determine which sensor is in need of repair. Then, remove the two screws holding it on the front bumper.
Feed the wires for the sensor's circuit plug back through the hooks on bObi's bumper.
Then, plug it into the empty spot on bObi’s cover circuit board.
To finish off this repair, follow the closing bObi manual: Closing bObi's Cover Post-Repair
To reassemble bObi, refer to the Closing bObi Guide.
