Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will teach you how to remove, clean, and replace the front wheel on bObi.
Parti
Nessuna parte specificata.
  1. Turn the front wheel so it faces bObi's front touch sensors. Grip the wheel and pull straight up.
    • Turn the front wheel so it faces bObi's front touch sensors.
    • Grip the wheel and pull straight up.
    • You may use a screwdriver for leverage when removing the wheel.
  2. This step is only necessary when cleaning the wheel. Skip to step 4 for instructions on installing a new wheel. To disassemble and deep clean the wheel, remove two small screws found on the bottom of the wheel. Then you can open it.
    • This step is only necessary when cleaning the wheel. Skip to step 4 for instructions on installing a new wheel.
    • To disassemble and deep clean the wheel, remove two small screws found on the bottom of the wheel. Then you can open it.
    • Grip the actual wheel and pull up to detach and clean beneath it. Use the screwdriver as leverage if you have difficulty separating the parts.
  3. This step is only necessary when cleaning bObi's front wheel. Skip to step 4 for instructions on installing the wheel. After cleaning, replace the small spring piece inside the wheel. Hold the wheel cover back together and install the two screws.
    • This step is only necessary when cleaning bObi's front wheel. Skip to step 4 for instructions on installing the wheel.
    • After cleaning, replace the small spring piece inside the wheel.
    • Hold the wheel cover back together and install the two screws.
    • Place the small wheel back in its space and apply pressure until it reattaches.
  4. Place the wheel back in bObi. Make sure it faces in the same way as it did when removing (wheel closer to bObi's front).
    • Place the wheel back in bObi. Make sure it faces in the same way as it did when removing (wheel closer to bObi's front).
    • Push down and the wheel will attach to bObi.
Conclusione
Chelsea
Membro da: 24/09/2014
2.278 Reputazione
31 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 768
