Introduzione
This will serve as a guide for the replacement of a Zune Flash 2nd Generation battery and memory board.
Cosa ti serve
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
At this point the LCD screen should be easily separable from the device.
It's safest to flip the display over before removing the ribbon, as shown in the first image.
To avoid damage, remove the LCD by pulling slowly and carefully on the ribbon, directly away from the memory board.
Detaching the memory board from the battery requires desoldering the 4 joints on the memory board.
It will be easiest to go in the order blue, yellow, black, red.
Altre 2 persone hanno completato questa guida.
2 Commenti
Guide doesn’t mention that the display ribbon is sometimes held down by adhesive near the connector
Can the battery be replaced without removing the display? We need guides specific to each.
Tbh I came to see what the battery looked like so I can order the right one. I learned 2 really good things from this post actually. I learned these used clips and not glue as well S the proper battery. Thanks ifixit peeps. Also, sickcodes is the man and you guys should totally work with him more often. You guys are great as well. -- sanad
sanadnesheiwat0301 - Replica
