Salta al contenuto principale
Introduzione
In this guide, we will take you through a step-by-step approach on how to replace a broken graphics card fan specifically the Zotac GTX 1080 Ti Mini. A couple of reasons why you might need to do the replacement is the graphics card fans can stop functioning efficiently, become noisy, or completely stop working. In order to fix these problems, you can use the guide to help.
  1. Be sure to properly ground yourself with an anti-static wristband before working on the graphics card. Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud. Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Look for the fan header located beside the 16-pin power connector. Gently pry the fan connector apart from the header with a flathead screwdriver.
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Slowly and carefully lift the shroud off the heatsink. During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver. Remove the broken fans. Remove the broken fans.
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Place the replacement fan on top of the heatsink with the screw holes aligned. Screw the fans into place using a Phillips #0 screwdriver. Screw the fans into place using a Phillips #0 screwdriver.
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Reconnect the fan connector to its header.
    • Reconnect the fan connector to its header.
  8. Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver. Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver. Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Conclusione
Hopefully, your graphics card is fully replaced and completely working now.
Victor Pan
Membro da: 27/01/2021
157 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 75
