Introduzione
In this guide, we will take you through a step-by-step approach on how to replace a broken graphics card fan specifically the Zotac GTX 1080 Ti Mini. A couple of reasons why you might need to do the replacement is the graphics card fans can stop functioning efficiently, become noisy, or completely stop working. In order to fix these problems, you can use the guide to help.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
Hopefully, your graphics card is fully replaced and completely working now.
Un commento
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
