Salta al contenuto principale
Zoomer Show Pony Power and Volume Switch Replacement
Cosa ti serve
  1. Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, immagine 1 di 3 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, immagine 2 di 3 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, immagine 3 di 3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Power and Volume Switch Replacement: passo 2, immagine 1 di 3 Zoomer Show Pony Power and Volume Switch Replacement: passo 2, immagine 2 di 3 Zoomer Show Pony Power and Volume Switch Replacement: passo 2, immagine 3 di 3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
Conclusione
USF Tampa, Team S20-G5, Passmore Spring 2018 Membro di USF Tampa, Team S20-G5, Passmore Spring 2018
USFT-PASSMORE-S18S20G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 756
