Salta al contenuto principale
Zoomer Show Pony Leg Motor Replacement
Cosa ti serve
  1. Zoomer Show Pony Leg Motor Replacement, Power and Volume Switch: passo 1, immagine 1 di 3 Zoomer Show Pony Leg Motor Replacement, Power and Volume Switch: passo 1, immagine 2 di 3 Zoomer Show Pony Leg Motor Replacement, Power and Volume Switch: passo 1, immagine 3 di 3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Leg Motor Replacement: passo 2, immagine 1 di 3 Zoomer Show Pony Leg Motor Replacement: passo 2, immagine 2 di 3 Zoomer Show Pony Leg Motor Replacement: passo 2, immagine 3 di 3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Zoomer Show Pony Leg Motor Replacement, Speaker: passo 3, immagine 1 di 1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. Zoomer Show Pony Leg Motor Replacement: passo 4, immagine 1 di 2 Zoomer Show Pony Leg Motor Replacement: passo 4, immagine 2 di 2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
  5. Zoomer Show Pony Leg Motor Replacement, Leg Spring: passo 5, immagine 1 di 3 Zoomer Show Pony Leg Motor Replacement, Leg Spring: passo 5, immagine 2 di 3 Zoomer Show Pony Leg Motor Replacement, Leg Spring: passo 5, immagine 3 di 3
    • Remove all five triangular screws located on the backside of the leg.
    • Remove the Phillips head screw holding the white leg bracket.
    • The white bracket MUST be re-connected in the same orientation. Make sure to note which side is up and down. The part looks symmetric to the blind eye but it is not.
    • Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
  6. Zoomer Show Pony Leg Motor Replacement: passo 6, immagine 1 di 3 Zoomer Show Pony Leg Motor Replacement: passo 6, immagine 2 di 3 Zoomer Show Pony Leg Motor Replacement: passo 6, immagine 3 di 3
    • Lift up on the plastic housing located on the upper portion of the leg (where it connects to the body).
    • Carefully separate the plastic housing at the base of the leg.
    • Remove slowly, there are small components attached to the motor that could become loose and/or missing.
  7. Zoomer Show Pony Leg Motor Replacement: passo 7, immagine 1 di 1
    • The spring will be exposed as shown. Remove the broken or damaged spring and replace it with a new one.
    • Spring must be in the "loaded position" when reassembling (there should be some resistance).
  8. Zoomer Show Pony Leg Motor Replacement, Leg Motor: passo 8, immagine 1 di 3 Zoomer Show Pony Leg Motor Replacement, Leg Motor: passo 8, immagine 2 di 3 Zoomer Show Pony Leg Motor Replacement, Leg Motor: passo 8, immagine 3 di 3
    • Pull motor out of pink wheel
    • Remove pin (red), plastic piece connected to pin (orange), and plastic rim around motor (blue).
  9. Zoomer Show Pony Leg Motor Replacement: passo 9, immagine 1 di 1
    • Replace motor
Conclusione
USF Tampa, Team S20-G5, Passmore Spring 2018 Membro di USF Tampa, Team S20-G5, Passmore Spring 2018
USFT-PASSMORE-S18S20G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 91
Tutti i Tempi: 742
