Salta al contenuto principale
Zoomer Meowzies Battery Replacement
Cosa ti serve
  1. Zoomer Meowzies Battery Replacement, Battery: passo 1, immagine 1 di 2 Zoomer Meowzies Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: passo 2, immagine 1 di 2 Zoomer Meowzies Battery Replacement: passo 2, immagine 2 di 2
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Conclusione
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 865
