Salta al contenuto principale
Zoomer Jurassic World Indominus Rex Mouth Part Replacement
Cosa ti serve
  1. Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: passo 1, immagine 1 di 2 Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: passo 1, immagine 2 di 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Part Replacement: passo 2, immagine 1 di 3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: passo 2, immagine 2 di 3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: passo 2, immagine 3 di 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
Conclusione
Anh Le
Membro da: 01/20/16
504 Reputazione
3 Guide realizzate
USF Tampa, Team 10-3, Remmell Spring 2016 Membro di USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,161
