Introduzione
The requirements for this guide are the right tools and the device itself. The motherboard should be removed when trying to access the internal components of the recorder.
Cosa ti serve
Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
Gently remove three ribbon connectors from the device.
The first is connected to the mic connector.
The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
Altre 5 persone hanno completato questa guida.
13 Commenti
Good night Mr.
I have a H6 recorder H.6 handy recorder, never use, but the battery stay in and it leak in the box.
When i remove the leaking battery, and i renew the battery the recorder did not start. According a technician the aparatus have to be open and chance the plate, but we does not have those technician on the island. please advice.
Edgar.
hello, i just have a question, where can i find this parts?
Can i get Zoom H6 Handy Recorder Motherboard only i need it and the price
Yes here ! https://shop.audiotronic.fr/en/61-h6
