Salta al contenuto principale
Zoom H1 Handy Recorder Battery Terminal Replacement
Cosa ti serve
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: passo 1, immagine 1 di 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 3, immagine 1 di 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 4, immagine 1 di 1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 5, immagine 1 di 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 6, immagine 1 di 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 7, immagine 1 di 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 8, immagine 1 di 2 Zoom H1 Handy Recorder Battery Terminal Replacement: passo 8, immagine 2 di 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 9, immagine 1 di 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: passo 10, immagine 1 di 1
    • Place second lead at point 2 and re-solder.
Conclusione
To Re-construct device, perform these steps in reverse order.
Alex
Membro da: 10/28/13
809 Reputazione
5 Guide realizzate
7 Commenti
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Replica
Mine has third screw under the serial-number sticker.
halluciana - Replica
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Replica
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Replica
Same problem, without any reason it is dead
eevilcute -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 6,372
