Salta al contenuto principale
Zoll Impact Uni-Vent 731 Power Knob Kit Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement, Power Knob Kit: passo 1, immagine 1 di 1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake
    • Pg. 29
  2. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 2, immagine 1 di 1
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator
    • Pg. 29
  3. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 3, immagine 1 di 1
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”
    • Pg. 29
  4. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 4, immagine 1 di 1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module
    • Pg. 29
  5. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 5, immagine 1 di 1
    • Remove the bezel by loosening and removing the (7) 4-40 X ¼ screws that hold the bezel to the front case
    • Pg. 29
  6. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 6, immagine 1 di 1
    • On the membrane panel assembly, loosen the 6-32 X ¼ set screw using a 1/16 Ball Hex Driver (located in the power knob) and lift the damaged knob from the membrane panel
    • Pg. 30
  7. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 7, immagine 1 di 1
    • Place the replacement knob on the membrane panel switch -align with flat on switch –insert the included 6-32 X ¼ set screw and tighten
    • Pg. 30
  8. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 8, immagine 1 di 1
    • Install the new bezel by tightening the included (7) 4-40 X ¼ screws
    • Pg. 30
  9. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 9, immagine 1 di 1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position
    • Pg. 30
  10. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 10, immagine 1 di 1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws
    • Pg. 30
  11. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 11, immagine 1 di 1
    • Tighten the (4) 8-32 X 3 screws on the outer air intake
    • Pg. 30
  12. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: passo 12, immagine 1 di 1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS
    • Pg. 30
Conclusione
Emily
Membro da: 05/04/20
206 Reputazione
1 Guida realizzata
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Membro di Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 170
