Salta al contenuto principale
Zipper Stop Replacement
Cosa ti serve
  1. Zipper Stop Replacement, Stop: passo 1, immagine 1 di 1
    • Evaluate the damage and examine the zipper for any indications of fracture, misalignment, or looseness.
  2. Zipper Stop Replacement: passo 2, immagine 1 di 1
    • Align the zipper stop so the post is on the same side as the zipper slider.
  3. Zipper Stop Replacement: passo 3, immagine 1 di 1
    • Gently place the stop beneath the zipper teeth.
  4. Zipper Stop Replacement: passo 4, immagine 1 di 2 Zipper Stop Replacement: passo 4, immagine 2 di 2
    • After the stop has been positioned appropriately, clamp it in place with the needle nose pliers.
    • To ensure a snug fit, use firm pressure at multiple points to clamp the stop tightly around the zipper teeth.
  5. Zipper Stop Replacement: passo 5, immagine 1 di 1
    • To make sure the stop is firmly attached to the zipper track, gently tug on it after clamping it. Reclamp the stop if needed.
Linea Traguardo
Dejia P.
Membro da: 02/20/24
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 62
Tutti i Tempi: 94
