Salta al contenuto principale
Zenithink ZTPAD ZT280 C91 Front Panel Replacement
Cosa ti serve
  1. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 2, immagine 1 di 3 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 2, immagine 2 di 3 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 2, immagine 3 di 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Motherboard: passo 3, immagine 1 di 1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 4, immagine 1 di 1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 7, immagine 1 di 2 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 7, immagine 2 di 2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 8, immagine 1 di 1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 9, immagine 1 di 2 Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 9, immagine 2 di 2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Front Panel Replacement, Front Panel: passo 10, immagine 1 di 1
    • Remove the four highlighted screws using a Phillips #1 screwdriver.
    • For differentiation purposes, these screws are 4mm long and have a larger head than the rest of the screws.
  11. Zenithink ZTPAD ZT280 C91 Front Panel Replacement: passo 11, immagine 1 di 1
    • Starting from the top, slowly lift everything up out of the front panel.
    • Remove the front panel off of the device.
    • Be careful not to damage the ports along the bottom.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 130
