Salta al contenuto principale
Zenithink ZTPAD ZT280 C91 Back Panel Replacement
Cosa ti serve
  1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: passo 2, immagine 1 di 3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: passo 2, immagine 2 di 3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: passo 2, immagine 3 di 3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 175
