Introduzione
The Zenbre SoundBank Z3 bluetooth speaker is built for portable music. If your device speaker is producing no sound, low audio or damage, replacing the internal speakers can restore its performance and make the device last longer, plus keeping it out of landfill. This repair guide will provide you a step by step process of removing and replacing the speakers from the device. Soldering skill is needed to remove and replace the speaker, likely resolving problems of sound performance or broken speakers.
Cosa ti serve
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
