Introduzione
This step-by-step guide will help you replace a damaged camera on a Zeki TBQG884B tablet.
A proper functioning camera is essential for capturing photos, scanning documents and engaging in video calls. If the camera is faulty or damaged, replacing it will help restore these functionalities.
Cosa ti serve
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
Altre 2 persone hanno completato questa guida.
