Salta al contenuto principale
Zeki Droid Tablet Back Casing Replacement
Cosa ti serve
  1. Zeki Droid Tablet Back Casing Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Back Casing Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Back Casing Replacement: passo 3, immagine 1 di 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Back Casing Replacement: passo 4, immagine 1 di 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Back Casing Replacement: passo 5, immagine 1 di 1
    • Pull the speakers away from the back casing carefullly.
Conclusione
Wyatt Nelson
Membro da: 03/11/15
120 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 717
