Salta al contenuto principale
Zeepad 7DRK Speaker Replacement
Cosa ti serve
  1. Zeepad 7DRK Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Zeepad 7DRK Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: passo 2, immagine 1 di 2 Zeepad 7DRK Speaker Replacement: passo 2, immagine 2 di 2
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: passo 3, immagine 1 di 1
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
Conclusione
UMass Dartmouth, Team 6-8, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 92
