Salta al contenuto principale
Zebra ZP 450 Power Cord Replacement
Cosa ti serve
  1. Zebra ZP 450 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
  2. Zebra ZP 450 Power Cord Replacement: passo 2, immagine 1 di 1
    • Using the iFixit opening pick, remove the plastic cover.
  3. Zebra ZP 450 Power Cord Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the single 14 mm screw from the clamp that is holding the power cord.
    • Remove the power cord from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 181
