Introduzione
No button response or viewfinder image in your Zeal Optics iON goggles? Use this guide to replace a faulty button board, which also connects to the viewfinder lens assembly.
In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
  • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
  • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
  • Pull the rubber housing apart to release the first two clips.
Aggiungi Commento
Grab the inside of the plastic nose rest with your thumb and index finger.
  • Grab the inside of the plastic nose rest with your thumb and index finger.
  • Rotate the nose rest upwards until you feel that it is free from the lens.
Aggiungi Commento
  • Rotate the device 180 degrees.
  • Grab the top of the goggle frame that holds the camera assembly.
  • Rotate the frame outwards until you feel that the clips inside it are free.
Aggiungi Commento
  • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
Aggiungi Commento
  • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
  • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
Aggiungi Commento
  • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Aggiungi Commento
  • Peel back the rubber battery cover from the inner left side of the frame.
  • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
Aggiungi Commento
  • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
Aggiungi Commento
  • Pull the battery out of its recess in the frame.
    • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
Aggiungi Commento
  • Peel the rubber keypad cover up from the inner right side of the frame.
  • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
Aggiungi Commento
  • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
Aggiungi Commento
  • Hold the strap mount cover away from the frame and remove the keypad.
Aggiungi Commento
  • Grab the viewfinder housing and pull it out of its recess.
    • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
Aggiungi Commento
  • Place one of your hands near the center of the frame with your thumb next to the camera housing.
  • With your other hand, grab the camera housing and pull it up and out of the frame.
Aggiungi Commento
  • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
Aggiungi Commento
  • In the same manner described above, remove the battery from the frame.
Aggiungi Commento
  • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
  • Flip the viewfinder housing over 180 degrees.
  • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Aggiungi Commento
  • Pull the two halves of the viewfinder housing apart.
Aggiungi Commento
  • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
  • Be sure to pry up on the hinged flap, not the connector itself.
Aggiungi Commento
  • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
Aggiungi Commento
  • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
Aggiungi Commento
  • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
Aggiungi Commento
  • Remove the viewfinder lens assembly from the viewfinder housing.
Aggiungi Commento
  • Use the tip of a spudger to flip up the retaining flap on the button board data cable ZIF connector.
  • Be sure you are prying on the hinged flap, not the socket itself.
Aggiungi Commento
  • Remove the button board data cable from its socket on the button board.
Aggiungi Commento
  • Remove the three 4.5 mm Phillips screws securing the button board to the viewfinder housing.
Aggiungi Commento
  • Remove the button board from the viewfinder housing.
Aggiungi Commento
Conclusione
Eric Flores
Membro da: 31/07/2012
126 Reputazione
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 965
