Introduzione
This guide will show you how to replace the rear-facing camera. You will need a plastic opening tool, tweezers, two opening picks, and a Phillips #00 screwdriver to complete these steps.
Cosa ti serve
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Flip the phone over so that the screen is facing up.
Wedge the plastic opening tool between the screen and the rear panel.
Push up on the opening tool to separate the panel from the phone.
Continue to do this around the entire phone until the rear panel is no longer connected to the device.
Use the tweezers to peel off the yellow Kapton tape.
Use the plastic opening tool to remove the rear-facing camera from the motherboard.
