Salta al contenuto principale
ZTE ZMax Pro Charging Port Replacement
Cosa ti serve
  1. ZTE ZMax Pro Charging Port Replacement, Back Panel Assembly: passo 1, immagine 1 di 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Charging Port Replacement: passo 2, immagine 1 di 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Charging Port Replacement: passo 3, immagine 1 di 2 ZTE ZMax Pro Charging Port Replacement: passo 3, immagine 2 di 2
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Charging Port Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Charging Port Replacement: passo 5, immagine 1 di 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Charging Port Replacement: passo 6, immagine 1 di 2 ZTE ZMax Pro Charging Port Replacement: passo 6, immagine 2 di 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Charging Port Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Charging Port Replacement: passo 8, immagine 1 di 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Charging Port Replacement, Charging Port: passo 9, immagine 1 di 1
    • Use tweezers to remove the antenna.
  10. ZTE ZMax Pro Charging Port Replacement: passo 10, immagine 1 di 2 ZTE ZMax Pro Charging Port Replacement: passo 10, immagine 2 di 2
    • Use tweezers to peel off the tape at the bottom of the phone.
    Don't forget the ribbon cable connecting the board to the battery.
    Chris Pratt - Replica
  11. ZTE ZMax Pro Charging Port Replacement: passo 11, immagine 1 di 1
    • Wedge the plastic opening tool under the charging port board at the bottom of the phone.
    • Push down on the plastic opening tool so the board pulls away from the phone.
    • Continue to do this around the charging port board until it comes all the way off the phone.
    • The board is glued to the case so make sure to work around all edges to ease removal. Trying to pull it away from one edge can cause damage to the board.
    • After removing the charging port, the adhesive will not have as strong of a hold on the new charging port. This should not be an issue. However, if the adhesive strength is negligible, you can consider buying adhesive and applying it before inserting the new charging port.
Conclusione
Altre 11 persone hanno completato questa guida.
Cal Poly, Team S17-G3, Livingston Spring 2018 Membro di Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Membri
16 Guide realizzate
11 Commenti
Very nice BUT where do you get the replacement charging port?
Anthony Kearns - Replica
Where can I bye the parts
John Anderson - Replica
“Buy” as in purchase not “Bye” as in see you later.
Thomas Heward - Replica
How much is it cost to fix it
anna lightsey - Replica
My charging port was 5.79 with free shipping at
James T. -
The info below is how this seller/item is posted on Amazon. The price I previously posted is incorrect. The corrected amount is/was $6.97 with no shipping via prime membership!
↓↓↓↓↓↓ *As shown on Amazon posting* ↓↓↓↓↓↓
PHONSUN USB Charging Sync Data Type-C Port Charger Dock Connector for ZTE ZMAX PRO Z981
James T. -
Very well put together guide. Completed the task in about 5 min. Now all I have to do is find a reputable store or sight to get a new board from. Any suggestions?
I've ordered my replacement parts through Amazon. Specifically the seller I buy from has yet to let me down. They always ship quickly, without error, and the parts are good quality. The 1st and only time I've had difficulty, they promptly replaced the part no questions asked!
Best of luck going forward!
James
Email: James.oratrat.jt@gmail.com
James T. -
James
James T. - Replica
My charging port is soldered to the mother board. ZTE light pro v9 ,different from the one depicted. Good instructions though,
Terence Molloy - Replica
My charging port is soldered to the mother board. The port fell off the mother board. Difficult to see the connection ,
ZTE pro light v9. Regards.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 7,861
