Salta al contenuto principale
ZTE ZMAX Z970 Power Button Replacement
Cosa ti serve
  1. ZTE ZMAX Z970 Power Button Replacement, Battery: passo 1, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement, Battery: passo 1, immagine 2 di 2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Power Button Replacement: passo 2, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Power Button Replacement: passo 3, immagine 1 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 3, immagine 2 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 3, immagine 3 di 3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Power Button Replacement: passo 4, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement: passo 4, immagine 2 di 2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Power Button Replacement: passo 5, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Power Button Replacement: passo 6, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement: passo 6, immagine 2 di 2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Power Button Replacement, Power Button: passo 7, immagine 1 di 3 ZTE ZMAX Z970 Power Button Replacement, Power Button: passo 7, immagine 2 di 3 ZTE ZMAX Z970 Power Button Replacement, Power Button: passo 7, immagine 3 di 3
    • Remove the black tape covering the motherboard.
    • Remove the single 1.2mm screw with a Phillips #000 screwdriver.
  8. ZTE ZMAX Z970 Power Button Replacement: passo 8, immagine 1 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 8, immagine 2 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 8, immagine 3 di 3
    • Use the flat end of the spudger to release the upper left and right prongs that secure the motherboard.
    • Detach the antenna cable.
  9. ZTE ZMAX Z970 Power Button Replacement: passo 9, immagine 1 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 9, immagine 2 di 3 ZTE ZMAX Z970 Power Button Replacement: passo 9, immagine 3 di 3
    • Lift up the tan flap on the three ZIF connectors.
    • Pull the ribbon out of the now unlocked ZIF connectors.
  10. ZTE ZMAX Z970 Power Button Replacement: passo 10, immagine 1 di 2 ZTE ZMAX Z970 Power Button Replacement: passo 10, immagine 2 di 2
    • Lift the covering panel below the motherboard covering and connecting the power button.
    • Disconnect the circuit tape of the power button and remove the power button.
    • The power button in these photos has been damaged and not soldered to the motherboard.
    • The new power button will have to be desoldered to the mother board.
Conclusione
Burak Cengiz
Membro da: 02/15/18
480 Reputazione
4 Guide realizzate
USF Tampa, Team S17-G3, Boczar Spring 2018 Membro di USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 517
