Salta al contenuto principale
ZTE Z667T Speaker Replacement
Cosa ti serve
  1. ZTE Z667T Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
  2. ZTE Z667T Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the battery by inserting your fingernail at the top of the battery and lift up.
  3. ZTE Z667T Speaker Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the five screws located on the back case.
  4. ZTE Z667T Speaker Replacement: passo 4, immagine 1 di 1
    • Gently pry open the back case using the plastic opening tool.
    • Pry open in multiple locations to avoid damage.
  5. ZTE Z667T Speaker Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tool, gently lift the speaker out of the back case.
Conclusione
Michael Lidbetter
Membro da: 02/12/18
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 154
