Salta al contenuto principale
ZTE Tempo Front Screen Assembly Replacement
Cosa ti serve
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: passo 1, immagine 1 di 2 ZTE Tempo Front Screen Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: passo 2, immagine 1 di 3 ZTE Tempo Front Screen Assembly Replacement: passo 2, immagine 2 di 3 ZTE Tempo Front Screen Assembly Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, immagine 1 di 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, immagine 2 di 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: passo 3, immagine 3 di 3
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: passo 5, immagine 1 di 2 ZTE Tempo Front Screen Assembly Replacement: passo 5, immagine 2 di 2
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: passo 6, immagine 1 di 3 ZTE Tempo Front Screen Assembly Replacement: passo 6, immagine 2 di 3 ZTE Tempo Front Screen Assembly Replacement: passo 6, immagine 3 di 3
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 305
