Introduzione
In this guide you will be able to replace the front/rear facing camera. Soldering background required.
Cosa ti serve
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
Remove the back casing by taking the motherboard and back casing and pulling them apart.
identify which camera you wish to replace, If it is still attached you must remove the headphone jack using the heat pen on your soldering station on top of the headphone jack until it becomes loose.
Gently remove the camera using tweezers.
