Salta al contenuto principale
ZTE Telstra T95 Battery Replacement
Cosa ti serve
  1. ZTE Telstra T95 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Battery Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
Conclusione
Gateway, Team 1-1, Johnson Fall 2014 Membro di Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 361
