Salta al contenuto principale
ZTE Speed Earpiece Speaker Replacement
Cosa ti serve
  1. ZTE Speed Earpiece Speaker Replacement, Motherboard: passo 1, immagine 1 di 2 ZTE Speed Earpiece Speaker Replacement, Motherboard: passo 1, immagine 2 di 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Earpiece Speaker Replacement: passo 2, immagine 1 di 2 ZTE Speed Earpiece Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Earpiece Speaker Replacement: passo 3, immagine 1 di 2 ZTE Speed Earpiece Speaker Replacement: passo 3, immagine 2 di 2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Earpiece Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Earpiece Speaker Replacement: passo 5, immagine 1 di 3 ZTE Speed Earpiece Speaker Replacement: passo 5, immagine 2 di 3 ZTE Speed Earpiece Speaker Replacement: passo 5, immagine 3 di 3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Earpiece Speaker Replacement: passo 6, immagine 1 di 2 ZTE Speed Earpiece Speaker Replacement: passo 6, immagine 2 di 2
    • Carefully take off motherboard.
  7. ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: passo 7, immagine 1 di 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: passo 7, immagine 2 di 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: passo 7, immagine 3 di 3
    • The earpiece speaker is located at the top-middle of the phone.
    • Using the plastic opening tool, carefully press into side of earpiece speaker and push up.
    • You will then be able to grab the speaker with your figers and remove it.
Conclusione
Garrett Barry
Membro da: 03/04/16
722 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 418
