Salta al contenuto principale
ZTE Quest n817 Motherboard Replacement
Cosa ti serve
  1. ZTE Quest n817 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 ZTE Quest n817 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 ZTE Quest n817 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: passo 2, immagine 1 di 2 ZTE Quest n817 Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: passo 4, immagine 1 di 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: passo 7, immagine 1 di 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: passo 8, immagine 1 di 2 ZTE Quest n817 Motherboard Replacement: passo 8, immagine 2 di 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 494
