Salta al contenuto principale
ZTE Maven 3 Speaker Replacement
Cosa ti serve
  1. ZTE Maven 3 Speaker Replacement, Back Cover: passo 1, immagine 1 di 3 ZTE Maven 3 Speaker Replacement, Back Cover: passo 1, immagine 2 di 3 ZTE Maven 3 Speaker Replacement, Back Cover: passo 1, immagine 3 di 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Speaker Replacement, Battery: passo 2, immagine 1 di 3 ZTE Maven 3 Speaker Replacement, Battery: passo 2, immagine 2 di 3 ZTE Maven 3 Speaker Replacement, Battery: passo 2, immagine 3 di 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Speaker Replacement, Midframe: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Speaker Replacement: passo 4, immagine 1 di 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Speaker Replacement: passo 5, immagine 1 di 2 ZTE Maven 3 Speaker Replacement: passo 5, immagine 2 di 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Speaker Replacement, Speaker: passo 6, immagine 1 di 1
    • Put the midframe on its back and locate the speaker on the bottom left corner.
  7. ZTE Maven 3 Speaker Replacement: passo 7, immagine 1 di 1
    • Gently lift the speaker out of the midframe using your fingers or a tool.
Conclusione
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 19
