Salta al contenuto principale
ZTE Maven 3 SIM Card Replacement
Cosa ti serve
  1. ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, immagine 1 di 3 ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, immagine 2 di 3 ZTE Maven 3 SIM Card Replacement, Back Cover: passo 1, immagine 3 di 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 SIM Card Replacement, SIM Card: passo 2, immagine 1 di 1
    • Locate the SIM Card slot on the upper left middle of the phone.
    • Remove the SIM card carefully from the back of the phone by gently sliding the card up and lifting it. Put the SIM to the side.
    • Gently pop in the new sim card where the old one was just removed.
Conclusione
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 36
